580 GTX Freezing (Problem localized)
Hi all! I am one of these user that always hace problems hehehe.
My computer was running fin for months but now since last week a weird thing is happening. When i play max payne or a game that requires a big gpu effort for 20 minutes, a black screen appears and the gpu fans starts to run at max speed.
At first I thought it was because of the temperature so, I increased the fans speed and checked the tenperature with my G15 but it was fine (75º max).
Then I restored the overclocks of the rams and the cpu. but nothing.
Then I tried a mem test and everything was ok.
As days go by the freezing appears before.
I tried to disable the sli and it worked fine. I tried also one card at each time and its ok. As it was working fine before and nothing changed I think the problem is the PSU or the motherboard.
The psu is a corssair 1000HX and the motherboard a G1. Guerrilla.
As far as i know, when the mb dies it fails more so i think my psu is not giving enough power when sli is active.
Any suggestions?
Thank you so much!!!
PD i tried a clean drivers install and all that ***...
1 answer Last reply
More about freezing problem localized
  1. News. SLI activated. CPU Voltage to "AUTO" the MHZ is set to default. for RAM and CPU and a case fan is disconected from the motherboard. Now it seems that is not freezing (just played 20 minutes, but before that the game was freezing just in 1 or 2 minutes). Still thinking that the PSU is not giving enough power cause before I dind't have those things down and it worked fine and as I said the motherboard shouldn't be the problem... Cause I broked many MB and when they are broken the pc is not starting or not letting me play the game, right?
    Any idea?
Nvidia Graphics
