First Build, am i doing it right?
So i never built a pc before so i watched a bunch on video online and read about them so i want to know if im doing it right.
I found all the parts on newegg.com
Case:http://www.newegg.com/Product/Product.aspx?Item=N82E16811139010
CPU:http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Mother Board:http://www.newegg.com/Product/Product.aspx?Item=N82E16813131848
Power Supply:http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Hard Drvie:http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
Ram:http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
Video Card:http://www.newegg.com/Product/Product.aspx?Item=N82E16814130660
Optical Drive:http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031
I want a pc for gaming and everday uses so if you can make better choices for parts that would be awesome and if im missing anything add them to the list.
1 answer Last reply
More about first build right
  1. Hello buddy, check out my signature builds!
Homebuilt Systems Product
