Will This GPU Fit in This Case? Help!
im soon to be buying my parts for my new upcoming gaming rig. I just need to know if the MSI Radeon HD 7870 Hawk Edition will fit in the case i want to buy. The Case is the Cooler Master Storm Enforcer.
Links:
-GPU (MSI Radeon HD 7870 Hawk Editon) http://pcpartpicker.com/part/msi-video-card-r7870hawk
-Case (Cooler Master Storm Enforcer) http://pcpartpicker.com/part/cooler-master-case-sgc1000kwn1
-Mobo (ASRock Z77 Extreme 4) http://pcpartpicker.com/part/asrock-motherboard-z77extreme4
Thanks in advance!
-JP
6 answers Last reply
More about will case help
  1. id suggest a build for you but i will say it will fit
    id get this instead
    http://us.ncix.com/products/?sku=67748&vpn=FX795ATDFC&manufacture=XFX&promoid=1084
  2. It should be able to fit in the Storm Enforcer for sure, especially if you remove one of those drive brackets.
    id get this instead
    Dude, that would look awesome in the storm enforcer too. I like the red and black theme on that card.
    id get this instead
    Yeah i would love to get the 7950 but its 100 bucks more and kind out of my budget. 7870 fits my needs perfectly for the games im going to play. thanks for suggest though.
  5. oh ok then. just remember the xfx double dissipation 7870 is 20 dollars cheaper than the msi after MIR
    sweet im going with the XFX DD 7870, Perfect colors and 2 fans! THANK YOU!
New Build Cooler Master Cases Radeon GPUs Systems Product MSI-Microstar
