Is a sound card worth the big bucks?
Last response: in Components
- Is it worth paying $30 more bucks for a 3 gb graphics card than a 2 gb of the same exact kind? - Forum
- Asus Xonar DGX Sound Card: Worth It? - Forum
- MSI Big Bang Mpower Z77 and fitting a sound card into the PCIe 1x slot - Forum
- Big sound From GFX card and system restarts automatically.Plzz HElp!!!!! - Forum
- Is it worth buying a $40 sound card? - Forum
- SolvedIs a sound card or expensive headset worth it? Forum
- SolvedIs it worth buying a sound card? Forum
- SolvedIs a sound card worth it? Forum
- SolvedIs it worth getting a new sound card? Forum
- SolvedSound card worth it? Forum
- Solvedis buying a refurbished sound card worth it Forum
- Solved2013 - Is it worth it/ possible to find a decent gaming sound card? Forum
- SolvedNew sound card worth it? Forum
- SolvedIs the Sound Card worth it? Forum
- SolvedBang for buck sound card Forum
- Is it worth getting a sound card? Forum
- SolvedAMD FX 8350 VS 8320. Worth extra 40 bucks? Forum
- SolvedMSI R9 280 $200 vs Asus R9 280x $299. Is the 100 bucks worth it in performance ?? Forum
- SolvedSound Card, Is the sound difference worth it? IF so, which card? Forum
- SolvedIs a worth it to get a Sound Card? Forum
- More resources
Read discussions in other Components categories
