No output signal from gpu to monitor
taiqi121
6
Hi guys,
I recently just built my new desktop with the following specs
MSI DDR3 1600 Intel LGA 1155 Motherboards (Z77A-G43)
HIS 7850 IceQ H785QN2G2M
Intel Core i5 3570K
(if you want the rest i can give but i think these are the important ones)
So I've tried both HDMI and VGA cables when connected to the GPU and both won't give a signal...but they will from the integrated graphics from the CPU, any ideas/fixes would be great because i'm a little lost, thanks
If the card works it will have a display before drivers are installed. If it does not work and you only have display from the onboard the computer will not detect it at all and therefore you can not install the drivers.
