Tranferring parts... Fatal?
  • Power Supplies
  • Cases
  • ATX
  • Components
Last response: in Components
January 16, 2013 7:57:25 AM
So I called a store to work on my parts transfer (from micro ATX to mid tower ATX case) instead of me. And they said, transferring my old rig to a new case is a 50-50 on whether it will turn on or not. :o  Is it really that fatal transferring the parts?
More about : tranferring parts fatal
January 16, 2013 8:02:20 AM
I can't count the number of cases I've transferred kit to - as long as you take your time, there's nothing to worry about at all.
m
l
January 16, 2013 8:09:32 AM
They are a computer store how come they don't know about a thing or two about "static" or whatsoever... :) ) Oh well, thanks kyzarvs! :p  :D  tsk i think they should close shop :) )
m
l
a b ) Power supply
January 16, 2013 8:23:37 AM
They probably are hoping to sell you new stuff, unless they are complete idiots, I give THAT a "50-50"
m
l
January 16, 2013 8:28:35 AM
Just thinking... the office server here has been in three different Antec cases, my gaming box has been in 2 Antecs and a Silverstone case. Same precautions as a new-build / upgrade - static management and patience are the only requirements.
The only gotcha I'd suggest (and it's nothing like as big a problem these days) on transferring everything to a new case is to make sure the mobo-mounts all line up and you don't have any pre-installed in the case that don't line up with mounting holes. Everything else is just time and patience.
m
l
a b ) Power supply
January 16, 2013 8:34:20 AM
50-50 is ridiculous. If you are competent and careful it will be 100% fine it's the same as removing all the parts for upgrade and then building a new pc.
You don't hear them saying "Yes we can build you a new PC but it's 50-50 whether it will work and we will still charge you".
m
l
January 16, 2013 10:45:25 PM
what do you mean by patience? is there a time frame when to disconnect wires and to disassemble everything? :)  like for example I'll them not do disassemble the processor and its fan and just transfer the whole mobo to the new case :D
exactly my point. :D
m
l
