Solved
Power cable touching GPU heat sink
  • New Build
  • GPUs
  • Power Supplies
  • Heat
  • Cable
  • Power
  • Systems
Last response: in Systems
September 2, 2012 3:09:47 AM
I have a power cable that runs from my power supply at the bottom of my case, to the power slot at the top of my mobo, and it has to go over my graphics card to do this (because it's a short wire). It unfortunately hast to touch the heat sink of my GPU, like this.
Is this safe?
More about : power cable touching gpu heat sink
Best solution
a b ) Power supply
September 2, 2012 3:30:09 AM
Not sure, isn't there any way to stop if from touching? Maybe at some tape?
September 12, 2012 12:31:46 AM
Best answer selected by danweb.
m
l
