Hey all -
So after a long and arduous build, I've finally completed a PC that seems to be working hunky-dory with one exception.
I installed my Auzentech Forte card that I got a few years ago and wasn't able to use in the last build. It's a fantastic soundcard, but the original run had some sensitivity to EMI that would create buzzing noises; wrapping the bracket in electrical tape generally fixed it, and had on the last build before I took the card out. Here, it was back with a vengeance.
I figured it was an issue with the card, and while waiting on Auzentech support switched to the mobo's built-in audio...only to find the exact same phenomenon. The plugs are located on opposite ends of the case and there's even completely different drivers. The headphones in question worked fine on the previous computer, so it's definitely a system issue.
I'm assuming there's just a ton of EMI, but I'm not sure what would be causing it - I got a fairly nice PSU (Rosewill Capstone 550M). Are there any standard processes for tracking this down or otherwise resolving an issue like this? I would like to have decent sound on my PC
It's worth noting that it's fairly mild while the system is idle, and becomes quite loud when under load, which is why I'm thinking EMI.
