Hello Tom's Hardware Community,
I have recently started building my own Gaming Machine and would like some help with,
1) Organizing and Analyzing what Products will be best suited to my needs.
2) Checking that Products are compatible with each other.
3) Any recommendations that you may have.
I will want my PC for gaming, i will want to play games like Crysis and other FPS games but the key point is that i want to be able to play them on the highest quality with no game stuttering or offline lag because the components are too slow. Please keep this in mind when making any suggestions. I will be looking to spend about £1000 - £1200 on this machine.
So far i have bought my Case which is a Cooler Master HAF X as i know this does not massively effect any other components.
I assume the next Step is buying the Motherboard and CPU the two products i have been looking at are listed below:
Motherboard:
Asus Maximus V Extreme
http://uk.asus.com/Motherboards/Intel_Socket_1155/MAXIMUS_V_EXTREME/
CPU:
Intel i7 3770k
http://ark.intel.com/products/65523 (Not very good Example)
Could you please confirm that they are both good components, that they are compatible and also if there is anything better.
Kind Regards
Sam Colwill
Motherboard:
CPU:
Intel i7 3770k
Kind Regards
Sam Colwill
