Solved
Xion power supply, good or bad?
  • Power Supplies
  • Power
  • Components
  • Product
Last response: in Components
January 16, 2013 10:32:20 PM
I recently purchased this 1000w PSU to power my 7950, hopefully a second one later on. I haven't heard much from this brand, is it trustworthy or should I look into getting a new one? I haven't had any problems whatsoever and it runs very well (from what i can tell.)
also, could this PSU supply power a second 7950?
Link to PSU:
http://www.amazon.com/gp/product/B005HNF1FO/ref=oh_deta...
My pc:
i5-3570 (stock fan)
asrock b75m-dgs (soon to be sabertooth z77)
corsair vengeance 16gb (soon to 32 gb ,same brand)
sapphire 7950
ocz vertex 4 128gb
1tb HHD (too lazy to find the name)
xion 100w PSU
as well as 4x 140mm fans 2x 120mm fans and a HUE controller.
thank you in advance :D
More about : xion power supply good bad
Best solution
a b ) Power supply
January 16, 2013 11:32:49 PM
Personally, I wouldn't recommend the PSU. Take a look at this feedback at Newegg:
There seem to be some quality issues with the brand. I would recommend a Seasonic or Corsair any day over a Xion.
January 16, 2013 11:45:10 PM
Thanks for showing me that :D  I will look into getting a new PSU as soon as I have the money.
honestly, and I say this as I'm knocking on wood, its been running great! buttt looking at those reviews I'm seriously crossing my fingering in hope I got the best of the batch until I can get a new one :p
m
l
a b ) Power supply
January 17, 2013 12:10:22 AM
It may be fine for a while. I would not CF with it, regardless of its rating. I don't get a warm and fuzzy impression regarding how reliable it really is.
m
l
January 17, 2013 12:18:54 AM
CF? sorry I'm still getting learning the ropes :p  and I wont, I'm just glad it hasn't gone out on me.. yet...
m
l
a b ) Power supply
January 17, 2013 12:21:22 AM
CF = CrossFire. Sorry.
Using more than one GPU (video card) puts a heavy load on a PSU (power supply) and I wouldn't trust the Xion to live up to its rating under that kind of load, especially when gaming and pushing the power needs even higher.
m
l
January 17, 2013 12:32:25 AM
ohhh haha I should have figured that one out, that is my bad XD and I wont, I dont see another 7950 coming into play fro a long time! again thank you for your help!
m
l
a b ) Power supply
January 17, 2013 12:46:33 AM
Oh, and just throwing out there, if you do side-grade the power supply, as long as you get a reliable brand, you won't need more than a 850w PSU, even if you have two 7950s.
m
l
January 17, 2013 1:02:33 AM
which PSU brands would you recommend?
m
l
January 17, 2013 1:17:27 AM
Best answer selected by Wtfitsfeisty.
m
l
a b ) Power supply
January 17, 2013 1:22:57 AM
Seasonic and Corsair are the brands I recommend (and use).
m
l
a b ) Power supply
January 17, 2013 3:01:58 AM
That is a great choice
m
l
January 17, 2013 3:12:03 AM
thank you for your help COLgeek! :D
m
l
