Power Supply CPU slot on motherboard
Last response: in Components
- SolvedCpu power slot on motherboard Forum
- SolvedPower supply only has 8 pin CPU cable, but the motherboard only has a 4 pin socket? Forum
- Solvedcan i use 4 pins of a 8 pin cpu power connector (ATX motherboard is 8 pin connector power supply is 4) Forum
- Solved4pin CPU power supply with 8pin motherboard? Forum
- SolvedI bought MSI Z77MA-G45 motherboard and a Rosewill RG630-S12 power supply, case, memory,& CPU. I cannot find a 4 pin connector Forum
- SolvedI need to know if my CPU and GPU are compatible with my motherboard. Also, if I have the power supply to support it. Forum
- SolvedJust a question about my ram motherboard and CPU and power supply Forum
- Solveddoes my old power supply that im using with my core2duo e7500 and intel risin city dg41rq be ok for my new cpu and motherboard Forum
- SolvedGood cpu, motherboard, gpu, ram, and power supply build for 750 (or less)? Forum
- SolvedGood Power supply For 8 pin cpu motherboard Forum
- 8 pin motherboard cpu power, 2x4 pin chord from power supply, help me i'm so over my head Forum
- SolvedCPU, MotherBoard or 4 pin power supply? Forum
- SolvedMy graphic card does not have a slot for the power supply! Forum
- PLEASE HELP! Defective CPU, Motherboard OR Power supply?? Forum
- SolvedPOWER SUPPLY COMING IN MOTHERBOARD BUT SMPS AND CPU FAN IS NOT SPINNING AND ALSO Forum
- SolvedBudget Work/Gaming - Case, Motherboard, CPU, Power Supply - $250-$350 Forum
- MSI Z87 MPower Motherboard has 2 8 pin CPU connectors. Do both need to be connected to the power Supply? Forum
- Best Motherboard, Power Supply, case, and CPU combo for the Money? Forum
- I've just replaced my power supply. Motherboard. Graphics cars CPU and ram. My pc loads up and asks if I want to start in safe Forum
- More resources
Read discussions in other Components categories
