I always that it is that little 4 pin connector that provides power to the cpu, but now i am being informed that it is supplied from the system bus. So which is it?
4 pin connector, trying booting your PC without it plugged in
Then how is it that the cpu multiplies the frequency it receives from the system bus? i don't think the cpu receives power from more than one source does it?
Thats nothing to do with power. Thats the CPU's function. The motherboard/system is powered by a 24pin connector and the CPU by a 4 pin
o ic... but then that leads me to a different question. If the system bus has nothing to do with power (its data transfer I'm assuming) then how could it be that the ram cpu gpu and whatever else synchronizes itself with the system bus. It doesn't make sense that things synchronize themselves to something that doesn't receive or produce power.
