Sign-in / Sign-up
Wireless won't work
  • Configuration
  • Wireless
  • Laptops
  • Ethernet Card
  • Wireless Networking
Last response: in Wireless Networking
October 15, 2011 3:35:57 PM
Hello? Hi, why won't my laptop go wirless, I always have to be plugged in with the ethernet cord.
Thanks
More about : wireless work
a b D Laptop
a b F Wireless
October 15, 2011 8:13:52 PM
Is your routers wireless enabled, is the wireless on the laptop enabled, is it detected in device manager and drivers installed?
m
l
a b D Laptop
a c 91 F Wireless
October 15, 2011 8:39:43 PM
This topic has been moved from the section Windows 7 to section Wireless Networking by Area51reopened
m
l
October 25, 2011 12:42:12 AM
Yes, my router is in wireless, everything on the router is in working order. And the laptop is in the wireless mode.
What is detected in device manager and drivers ?
Thanks !!!
m
l
October 25, 2011 9:49:18 PM
das_stig is asking you to verify that the wireless adapter is showing in your device manager. Go to Control Panel -> Device Manager. Are there any black arrows showing?
Some laptops require you to turn on a switch to enable the wireless adapter. If you post the make/model of your laptop, we can help you much easier.
m
l
November 1, 2011 10:31:18 AM
Hi, NO, No black arrows. Now what ? Thanks
m
l
a c 854 D Laptop
a c 79 F Wireless
November 1, 2011 3:14:26 PM
Did you actually try to connect the laptop to your wireless network? What did you do to try to connect it, and what happened?
m
l
