Monitor Noise??
Forum Computer Peripherals : CRT Monitors - Monitor Noise??
I have a Samsung SyncMaster 17GLi monitor (running at 1024x768, 75Hz) and although the picture is just fine, there seems to be this strange noise coming from the monitor. Its hard to describe, but it's almost like some type of buzzing, very faint though, faint enough to be drowned out by music, but very annoying when there's no music playing. It's kinda like buzzing, but it doesnt' sound like a type of "produced" buzz, like electrical equipment might buzz for some error. It's more of an "electrical" type buzz (sorry, I'm trying my best with the description) that seems to be coming directly from within the monitor, maybe it's from the power supply in the monitor. But the noise goes away when i turn off the monitor, so I really can't figure out what the deal is with the noise. Also, this monitor has no integrated speakers or anything... the noise comes from within the monitor itself. During bootup, at lower resolutions (such as the boot screen) the buzzing is slower, i.e., it's almost like running your fingers very quickly across corrugated cardboard but times the speed by 100 (that's the 'buzzing' i'm talking about)... at lower resolutions the "buzzing" seems SLIGHTLY slower. So, any help?? Thanks much..
~ApT~
Running:
333 MHz Celeron (Slot1)
192 MB RAM
4 MB ATi Rage LT Integrated Video
ESS 1869 Integrated Audio
Comcrap (Compaq) mobo
Sponsored Links
Hmm, I wonder if dust is doing anything to it. Do you have a can of compressed air to blow dust out?
If u open up the CRT be very careful dangerous stuff in there (electrical even if the power plug is pulled)!!!
The loving are the daring!
Reply to Flinx
NEVER open a CRT unless you know what you're doing. The charge stored by a CRT is enough to kill you even after very extended periods of being unplugged.
If you're concerned about dust, use a can of compressed air and a vacuum cleaner, blow/suck through the venting on the case.
Reply to kinetic_tw
- 0 +
Try changing resolutions as well as changing the refresh rates at each resolution. Im not sure whether you're talking about a high-pitched noise, but the monitor I am currently using at the computer lab at my college was doing that when I sat down, and I just changed the resolution and it disappeared...femals tend to notice these things better, but it was really noticable to me (Im no female.... last time I checked).
Hope this helps in any way.
Tak
Remember, when in doubt, even monkeys fall from trees sometimes.
Reply to Tak
Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > Monitor Noise??
There are 637 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
