Help with a build
Hi Guys,
I need help with a build for high processing calculations (math/statistical ) and gaming.
Here is what i thinking to get, any suggestions are welcome.
Case - NZXT 410 Phantom
PSU - Corsair ATX 750W or NZXT ATX HALE 90 750W?
CPU - Intel Core i7-3930K
CPU Cooler - ??
Motherboard - ASUS Sabertooth X79 or ASUS Rampage IV Extreme?
Memory - Corsair Vengeance 16Gb(4x4GB) 1600MHz DDR3
Video Card - GTX 690 or GTX 680?
Storage - SSD OCZ Vertex 4 256GB SATA III
Optical Drive - LG Cd/Dvd/Blu-ray/ Burner 14x SATA
Thanks.
6 answers Last reply
More about help build
  1. What's your budget? You will most definitely need an aftermarket cooler with the 3930K since it doesn't come with one - Intel assumes most people willing to drop $600 on a CPU will have one already. I suggest the Noctua D14. It's also incredibly pointless to spend $1K on a video card when 2 $400 video cards will give you identical frame rates and you'll come out $200 ahead.
    What's your budget? I can suggest a system if I knew that.
  2. Yeah, i know that this CPU doesn't come with a cooler. I really don't know wich cooler to get.
    So you're saying that i should get 2 gtx 680?
    I'm more concerned building a system that can do a lot of math/statistical calculations, and maybe using 4 monitors.
    I really don't have a budget for this because i will use thiis system to work as well, so i'm thinking about this as an invesment :)
    No I'm saying two 670s will give you identical performance to a 690. See for yourself: http://hexus.net/tech/reviews/graphics/39605-nvidia-geforce-gtx-670-sli-vs-the-beasttm/?page=3
    But again if you give me a budget I can suggest a full build.
  4. Use a range between 2k-4k budget.
    BTW thanks for your help.
  5. Here you go:
    CPU: Intel Core i7-3930K 3.2GHz 6-Core Processor ($569.99 @ Newegg)
    CPU Cooler: Noctua NH-D14 SE2011 CPU Cooler ($89.99 @ Newegg)
    Motherboard: Asus Sabertooth X79 ATX LGA2011 Motherboard ($329.99 @ Newegg)
    Memory: Mushkin Blackline 16GB (4 x 4GB) DDR3-1600 Memory ($88.99 @ Newegg)
    Storage: Samsung Spinpoint F4 2TB 3.5" 5400RPM Internal Hard Drive ($119.99 @ Newegg)
    Storage: Crucial M4 256GB 2.5" Solid State Disk ($214.99 @ Newegg)
    Video Card: EVGA GeForce GTX 670 2GB Video Card (2-Way SLI) ($407.99 @ Newegg)
    Case: NZXT Switch 810 (White) ATX Full Tower Case ($145.99 @ Newegg)
    Power Supply: PC Power & Cooling 750W ATX12V / EPS12V Power Supply ($89.99 @ Newegg)
    Optical Drive: Lite-On iHES112-29 Blu-Ray Reader, DVD/CD Writer
    Operating System: Microsoft Windows 7 Professional SP1 (64-bit) ($139.99 @ Newegg)
    Total: $2605.89
    (Prices include shipping and discounts when available.)
    (Generated by PCPartPicker 2012-09-03 18:38 EDT-0400)
  6. Thank you very much for your help.
New Build Systems Product
