What's the best graphic card i can get for arma 2 on 300 watt system
  • Graphics Cards
  • Graphics
  • Product
July 16, 2012 9:43:08 PM
what's the best graphic card i can get for arma 2 on 300 watt system from £40-£75
More about : graphic card arma 300 watt system
July 16, 2012 9:56:51 PM
just looked and it says Minimum System Power requirement (W) 400W so would it still work?
a b U Graphics card
July 16, 2012 10:01:06 PM
Yeah they just say that to cover their behinds. What is the rest of your system? If you have a 95w TDP CPU or less you should be fine.
July 16, 2012 10:15:17 PM
athlon dual core 2.5 ghz 3gb ram 500gb hard drive windows 7
a b U Graphics card
July 16, 2012 10:17:17 PM
Yeah you're good, will run just fine.
July 16, 2012 10:19:43 PM
ok man thanks for the help :)
a b U Graphics card
July 16, 2012 10:21:56 PM
anytime boss ;)
