So I just moved to the US from Sweden and im in need of building a pc, I will fill out the template provided in the sticky.
Approximate Purchase Date: As soon as possible!
Budget Range: No more than 1700 (including screen) i can push for 1800 if need be,
System Usage from Most to Least Important: Gaming, school, surfing etc all the good stuff.
Are you buying a monitor: Yes
Parts to Upgrade: Everything except mouse, have the logitech g9x mouse
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg, even though I need to open up an american bank now because of them..
Parts Preferences: In additional comments
Overclocking: for sure down the line
SLI or Crossfire: yes, want to future proof
Your Monitor Resolution: not sure about what to get though, something that is LED backlit and at least 21 inches, and 2ms? not sure about the 60hz (hz is that right) compare to the 120 one? is it worth it?1980x 1080 lowest resolution?
Additional Comments: Ive picked most of my parts to my best knowledge over the last week or so, reading reviews, watching videos etc. But im unsure on the graphics card and Ram as there are soo many choices to pick from. Id like to get low profile Ram so i can use the nh d14 cpu heatsink that i plan on purchasing, but also what is the recommended mhz one needs? 1600? 2133? is there a big improvement between them?Also Id like to get 2x8 in order to have 2 free slots open for future proofing to 32 gb when its needed. Now the graphic card to me is quite overwhelming since there are so many manufactures, ive come to the conclusion I want a 670, im just unsure which one.. anyhow, here are the parts ive picked so far. Please any feedback is appreciated, if theres something better for cheaper or something in my list just plainly sucks let me know
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
LER MASTER Silent Pro Gold Series RS800-80GAD3-US 800W ATX 12V v2.3 / EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171057
Crucial M4 CT128M4SSD2CCA 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148448
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
ASRock Z77 Extreme6 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157295
Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5"
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
Along with these I also decided to get this pc tool kit just in case and a anti static wrist wrap.
Rosewill RTK-045 45 Piece Premium Computer Tool Kit
http://www.newegg.com/Product/Product.aspx?Item=N82E16899261003
XTRAC PADS Ripper Optical Mouse pad
http://www.newegg.com/Product/Product.aspx?Item=N82E16817114174
Microsoft SIDEWINDER X4 Keyboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109191
And Most Importantly, Why Are You Upgrading: New life in America means a new computer to build, also this is my first time, so im a little nervous as to how it will go. Also im sick of playing bf3 and other games on the lowest lowest settings in order to increase fps in mp games
Not sure if im missing any components if I did let me know!
really appreciate the help, dont know what I would do without the internet to help me (no computer?)
Thanks!
Thanks!
