Almost complete build test power on fail
Last response: in Systems
Hi, i am building this new rig. I am almost done. In fact, the only thing remaining for it to be functionnal is the CPU. I plugged it just now without the CPU to see if it powered on but it did not. I saw that the power led does light up tough. But none of the fans or the power supply fan did turn on. Not a sound or anything. I was wondering if it's because there's no CPU or if i should contact ASrock. The Power supply has not been used for two years and it's an antec earthwatt 500. It was working fine last time i used it tough.
Motherboard is an ASrock z77 pro4-m
Thank you
hmm not sure why you would power it on with no CPU? I am sure all mobos are different but it maybe wont boot without CPU. why dont you just put the CPU in and try again - if it works great, if not then its most likely wiring/psu, but you can investigate from that point and post back here.
good luck
Just wanted to see if it turned on at least. I'm buying components whenever i have the money for it. Over time. I realize now that it complicates things when you can't test any component until your build is complete. until then, waranty wears off.
But thank you for the answers.
Ask the community
