Silent fans, but loud noise from air through metal mesh?? Tags: Power Supplies Cases Mesh Corsair Components Last response: March 25, 2013 7:30 AM in Components Share Justin4280 January 19, 2013 8:12:47 PM Unforeseen problem here.. New case. I got a Corsair 300R which I love and I'd hate to have to cut it up 1 week into owning it. But when I install silent low speed fans to the metal door, at the metal honeycomb vent, the air rushing in the case makes a loud annoying noise. Am I going to have to cut the metal out? Anybody else heard of this problem? Thnaks More about : silent fans loud noise air metal mesh Justin4280 January 21, 2013 12:44:57 AM Come on.. nothing? m 0 l Skrufstark March 25, 2013 7:30:06 AM Having the same problem in my Corsair ob 650D with sickleflow fans from CM. I just ordered a cheap fan controller to turn them down a bit, it has not arrived tough but i would suggest you do the same to get the noise down a few Decibels. m 0 l Can't find your answer ? Ask ! Publish Read discussions in other Components categories Power supplies Sound cards NICs Akasa Antec Cooler Master Cougar DeepCool Enermax !
