Hi all..
I'm trying to stress test my GPU (GTX 460 core715, memo 1800, shader 1430) using OCCT, and I don't know if thats normal, but the fuzzy round object is not moving.. I'm getting 145fps on 1080p, and no errors, but the picture is still.. Is that normal?
I tried using MSI kombustor, and it worked normal I think, the fuzzy MSI is moving and image looks perfectly fine.. I got average 34fps on 1080p.
Also, are temperatures I find online in reviews like on tomshardware , supposed to be with Fan speed on default or 100% on?? the default of my GPU fan is %40 of its speed.. before I stress tested, I uped it to 80%, and got a load temperature of 74C (165F).. is that good considering fan on %80 and no overclocking (although the card I have is an overclocked edition)?
Thank you.
Thank you.
