Power supply wont fit.
  • Power Supplies
  • Cases
  • Components
  • Product
Last response: in Components
January 21, 2013 12:12:18 AM
Ok. So i ordered this case http://www.newegg.com/Product/Product.aspx?Item=N82E168... and this power supply http://www.newegg.com/Product/Product.aspx?Item=N82E168... but the power supply is just a tad bit to big, and I have no clue what power supply to get now, I thought they were universal in size wise, unless I have a micro PC, or mini. But for regular mid towers i thought it was universal. So I need help finding out what power supply with about 500w-600w would fit into my case. Thanks for your help.
More about : power supply wont fit
a c 311 ) Power supply
January 21, 2013 12:36:40 AM
How is it too big? Case is 7.5"wide, psu 5.9"w. Length & ht & I
can't see how the length or ht can't fit in 19"L x 18.3"h.
Tom
you gotta be doin something wrong
m
l
a b ) Power supply
January 21, 2013 1:06:03 AM
check the case to see if they placed a small rubber anti vibration pad in for the power supply. if they did that can make a standard ps not fit. I had that issue with my antec one case and a high end power supply.
m
l
a b ) Power supply
January 21, 2013 1:09:06 AM
What is the dimension for the power supply that is not fitting?
I agree with Tom.
m
l
a b ) Power supply
January 21, 2013 1:11:30 AM
Are you talking about the screw holes not lining up to the case?
m
l
a c 2489 ) Power supply
January 21, 2013 2:23:34 AM
Should fit in the case with no issues.
m
l
