Solved
Tri sli 470 gtx power requirement
  • Power Supplies
  • Gtx
  • SLI
  • Power
  • Components
Last response: in Components
January 21, 2013 4:09:13 AM
Debating going tri sli GTX 470s on a z77a-gd65.
Have a 3570k stable @ 4.4 ghz on 1.25 volt.
Would debate ocing the 470s to 750-800hz @ 1.087
Currently have seasonic x-850. Would that be enough to run my rig?
Thanks for the replies!
More about : tri sli 470 gtx power requirement
a b ) Power supply
January 21, 2013 4:29:12 AM
No i wouldn't.. just keep the 3 470's at stock..
m
l
January 21, 2013 7:07:30 AM
I haven't bought the third 470 yet.
Would I be able to handle a third on the x-850 with my set up?
m
l
January 21, 2013 7:23:50 AM
Your talking close to 800W when your system is in load. Personally I wouldn't push your PSU to that limit and if you OC your components you will probably be hitting pass 850.
If it were me I wouldn't.
m
l
January 21, 2013 7:44:54 AM
lol, soz bud. Think I missed that. My bad
m
l
a c 122 ) Power supply
January 21, 2013 7:46:31 AM
:lol:  no worries.
m
l
January 21, 2013 7:37:34 PM
What would be the consequences of doing so.
Aka, what are the worst things that could happen?
m
l
January 21, 2013 10:22:27 PM
While I am no expert isn't the Z77 limited to 16 lanes with out a PLX so if you tried to run 3 cards you would be in 8/8/4 best case but more likely in 4/4/4 or 8/4/4
m
l
January 21, 2013 10:24:42 PM
Looked it up your board is (16, 8, 4) I would guess the x4 is stolen from a different chip so x4 wouldn't get you much IMHO
m
l
Best solution
a c 1218 ) Power supply
January 21, 2013 10:38:19 PM
When using an Ivy Bridge Processor the three PCIe 3.0 x16 slots of the MSI Z77A-GD65 have the following possible support options:
x16/x0/x0
x8/x8/x0
x8/x4/x4
That means that 2-way SLI is the maximum supported. For the graphics card to be included in the SLI set the x16 slot must have a minimum of 8 PCIe lanes and only two of the three x16 slots on that motherboard have at least 8 PCIe lanes or more.
January 21, 2013 11:02:48 PM
Interesting. Does my motherboard just suck? I thought I did a fair amount of research
m
l
January 22, 2013 1:34:05 AM
3-way or 4-way SLI with an Intel Z77 Express chipset motherboard requires that the motherboard also have the PLX PEX8747 bridge chip.
Examples:
ASRock Z77 Extreme9
ASUS MAXIMUS V EXTREME
ASUS P8Z77-V PREMIUM
ASUS P8Z77 WS
ECS Z77H2-AX
EVGA Z77 FTW
Gigabyte G1.Sniper 3
Gigabyte GA-Z77X-UP7
m
l
January 22, 2013 3:16:06 AM
Examples:
ASRock Z77 Extreme9
ASUS P8Z77 WS
ECS Z77H2-AX
EVGA Z77 FTW
Wow, so way above what I was considering.
Thanks for the help!
m
l
January 22, 2013 3:17:00 AM
Best answer selected by therevaj.
m
l
