Hello all
Lately i have been thinking about improving my air cooling solution - Which is already pretty good. I think it is. Im a bit OCD when it comes to my temps, so i want to get them as low as possible. But now im at that point where i dont know what to do next. The most important components i want to lower temps for is GPU and CPU basicly. But wouldnt mind all temps were lowered.
Im not happy with water cooling cause i dont want to "risk it", you know? So im sticking with aircooling. I do know that water cooling has improved over the years, but i still dont trust it. Not yet.
My build is:
NZXT Phantom Full Tower(White)
Asus P8z68-Vpro
Corsair TX750v2 PSU
Core i5 2500k 4.5Ghz OC - Noctua NH-D14.
16 GB Kingston HyperX Genesis 2400 Mhz
Radeon HD6950 1050/1500 OC - Accelero Xtreme II+ cooler block, removed stock fans and added 2x120mm CoolerMaster SickleFlow R4 fans.
My temps are as following - Using Celsius.
Ambient 26c
IDLE
Cpu - 29-35c
MB - 27c
GPU - 33-34c
GPU Vrm - 34-36c
LOAD
Cpu - 56-59c(Prime95 and intelburn test) 50-55c when gaming.
MB - 31c
GPU - 50-61c (Kombuster, BF3, Crysis 2 with texture pack, and metro 2033)
GPU Vrm - 66c
As you may have noticed i have managed to get some, well, almost perfect temps on air cooling. I want to sqeeze it abit more and lower the temps even more. Even if its just a few degrees.
In the case i am using the stock fans that came within. Added another 192 mm fan on top and removed the side fans.
Front - 120 mm intake (Upgrading to 140 mm
Back - 120 mm exhaust
Top - 2x192 mm exhaust
CPU and GPU fans are connected to the fans controlpanel at the top.
I have also switched the meshed sidepanel out with a window sidepanel for better airflow, and got airfilters on intake and the meshed areas of the case. Also got nice cable management.
Temps difference between low and high fan speed is just 2-8c when in idle or load. GPU temps doesnt change between low and high speed with these fans.
Also, i am using HWmonitor, Intel Coretemp, CPU-z and GPU-z.
Before i started lowering my temps, they were:
CPU - 40-45 in idle and up to 75 on load.(had a Arctic cooling Freezer13)
GPU - 42-45 in idle and up to 85 on load, with no OC.(Stock xfx cooling)
GPU vrm - 5-10 c higher than GPU.
Which isnt the best. The CPU didnt like Prime95 or IntelBurnTest.
I think i have provided all the details for my case. Do i need to add more, please tell
Oh, forgot to add how o placed my PC. I've build a homemade. On top of it stands my screen(40" tv) and behind the screen i have the pc standing. Screen/tv generates lots of heat, but after several tests i found out that this doesnt interfere with my computer temps. Air space between TV and computer is about 28 cm and about 2 cm from window sidepanel to a cold concrete wall.
Would add pictures of temp readings if i wasnt a total nood about it..
As i write this my GPU is 32.5-34c and cpu is 31-36c
Thanks in advance
My build is:
Asus P8z68-Vpro
Corsair TX750v2 PSU
Ambient 26c
IDLE
Cpu - 29-35c
MB - 27c
GPU - 33-34c
GPU Vrm - 34-36c
LOAD
MB - 31c
GPU Vrm - 66c
Thanks in advance
