Approximate Purchase Date: As soon as i3-3225 is released, or this week if different CPU
Budget Range: <A$800
System Usage from Most to Least Important: HTPC, listening to music, watching DVD, record and playback TV, surf web, Skype - no gaming, already have an i5 with GTX670 for games!
Are you buying a monitor: No - Will be connected to HD TV
Parts to Upgrade: all new
Do you need to buy OS: No, already have Win7 and will be using Media Centre
Preferred Website(s) for Parts: www.pccasegear.com
Parts Preferences: Have used Intel, ASUS, Corsair in the past and been happy, but could branch out!
Overclocking: No - I don't think this CPU/MB supports OC
SLI or Crossfire: No - integrated graphics
Your Monitor Resolution: Full HD 1920 x 1080
Additional Comments: Quiet would be good, but doesn't have to be silent. Set up will be HTPC -> AMP -> TV all via HDMI cable.
Most data will be stored on NAS and streamed, only concern I have is when recording TV is it OK to go directly across the network, or better to record to a local HDD first, then copy files across later? (have included HDD ...)
And Most Importantly, Why Are You Upgrading: This is a new machine to complement new TV (just upgrade from old CRT!)
Parts
CPU = i3-3225 - has HD4000 graphics $150??
Motherboard = ASUS P8B75-M $75 or other??? Really not sure on which chip set I should be going for...
RAM = Corsair CMV4GX3M2A1333C9 4GB (2x2GB) DDR3 $27 or Corsair XMS3 CMX8GX3M2A1600C9 8GB (2x4GB) DDR3 $49
SSD = SanDisk Extreme 120GB $99
HDD = Seagate Barracuda 2TB $105
Optical = LG CH12LS28 12X BD-R Blu-ray DVD Combo Drive $55
Case = Silverstone GD05 Black HTPC Case with USB 3.0 $109 or Silverstone Grandia GD04 USB 3.0 HTPC Case Black $125 or other ???
PSU = Corsair CX-430 V2 Power Supply $59
Tuner Card = Hauppauge HVR-2210 Media Centre Kit $165
Total = Between $735 and $773
Any input would be greatly appreciated,
Thanks, Ox
Parts
Thanks, Ox
