Approximate Purchase Date: Next couple of weeks
Budget Range: Quality is somewhat going to trump price for me e.g. if it's really good and you think it's really good, I'll probably save for it/buy it.
System Usage from Most to Least Important: gaming mostly (high end/medium-high end)
Are you buying a monitor: No
Parts to Upgrade: CPU MOBO
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Newegg, amazon and tiger direct
Parts Preferences: Intel based I think
Overclocking: Yes/Maybe
SLI or Crossfire: Yes/not right away but in the future
Your Monitor Resolution: 1920x1080
Additional Comments: I think I can go a WEE expensive on the CPU and Motherboard if it's worth it.
I'm writing to ask the forums about ideas regarding a top-end or near top-end motherboard that will last me quite a while. I'm building my first PC, for gaming mostly, maybe a little bit of video/photo editing but gaming mainly. I know there are a lot out there and I've researched quite a few. Is there any way I can narrow it down? The price range I'm looking at is 150-300 or so, MAAYBE going higher depending on whether I can get more out of it in the future, so upgradability is key. Also, in conjunction with unpicked higher-mid-tier-mobo, which CPU would work best with it? Any and all advice would be greatly appreciated. I would like to get them very soon. I have this already:
1 x ($114.99) Corsair Carbide Series 500R Black Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
$114.99
1 x ($57.99) CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 Desktop Memory Model CMZ8GX3M2A2133C11B
$57.99
Delivery estimate: Sept. 11, 2012
1 "Corsair CX Series CX750 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Power Supply CP-9020015-NA"
Personal Computers; $86.00
In Stock
Sold by: Amazon.com
1 "Cooler Master Hyper 212 EVO CPU Cooler with 120mm PWM Fan (RR-212E-20PK-R2)"
Personal Computers; $32.08
In Stock
Previously considered mobo, CPU and other components are as follows:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
ASRock motherboard $134.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
i5 processor $229.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
dvd/cd optic drive $17.99
http://www.amazon.com/SanDisk-2-5-Inch-Solid-SDSSDP-128G-G25/dp/B007ZW2LY4
SSDrive 128GB $89.95
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Windows 7 HP $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
1TB WD Hard Drive (Internal) $84.99
And a GeForce GTX 580 from a while back that I have not had a chance to use. I would like to replace those with 670's SLI'd in the future, or at least the 660 Ti's. Any and all help would be greatly appreciated, It's my first one so I don't know much.
I think I'd prefer ASUS I guess because of the ease of installation, and Intel just because that's what I've used all my life.
I was also thinking to overclock in the future. I'm not entirely sure what that is yet, but I want the full potential out of the CPU I'd be getting.
$114.99
$57.99
In Stock
Sold by: Amazon.com
In Stock
Windows 7 HP $99.99
