Hello all
I am reluctantly entertaining the thought of a new build (this will be my third), as I last upgraded six years ago and my current system is beginning to show signs of wear and tear.
Approximate Purchase Date: 30-45 days
Budget Range: ~$1,500 before taxes
System Usage from Most to Least Important: gaming (World of Warcraft only), surfing the web, basic M/Office applications
Are you buying a monitor: No
Parts to Upgrade: Everything except the PSU (I have a Corsair AX750 which seems workable) and the case (I have a Lian Li PC-62 case which I'm happy to keep, unless you think it is too small for current GPUs or too noisy)
Do you need to buy OS: No
Preferred Website(s) for Parts: There is a TigerDirect just down the road from me. I would prefer to buy directly from the store.
Parts Preferences: I have always used Intel, but if an argument can be made for AMD I'm all ears. I prefer ASUS m/boards also.
Overclocking: No
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
Additional Comments/Why am I upgrading:
1. My main priority is noise reduction. At peak load, my current system sounds like a 747 ramping up for take-off. I would consider (for example) a less potent GPU if it meant a much quieter card. Ditto for everything else.
2. Notwithstanding the above, I believe there is considerable room for improvement on what I have. I am running an Intel Core 2 Duo at 2.4 Ghz on an ASUS P5W DH Deluxe board, with an NVIDIA GeForce 9600 GT GPU and 4GB of memory.
Many thanks in advance for any suggestions.
Overclocking: No
