G
Guest
Guest
I am trying to run my DVD player through my TV but I am having problems. First off here is my system specs:-
AMD Duron 750Mhz
Gigabyte 71XE4 M/Board
256Mb PC 100
Gainward Geoforce 2 400mx Golden Sample S-Video TV-Out
Fujutsu 20Gb MPG3204AT E HDD
LG DVD ROM DRD8120B
CyberDrv CW018D CD-R/RW
Rockwell HCF 56K Modem
Creative Ensoniq Audio PCI
Packard Bell 17" A726 Monitor
Win 98
Here is the story so far.
I have connected the PC to my TV as follows:-
My graphics card has an S video connector with an adapter cable for a standard video plug. I have connected the plug and audio from my sound card (using an adapter from a 3.5mm jack plug to twin audio cables) to the TV using the SCART plug.
I then set up the graphics card for twin view with one as the monitor and the other as a TV using PAL-I (for the UK).
I then followed the instructions for tuning the TV but I can't seem to get any signal. The SCART lead has an In/Out selector switch on it and the only thing I can get it to do is for the TV sound to play through my PC when I set it to the In position. Obviously I want it to go in the other direction!!!!!
Does anybody have any idea where I am going wrong or have any suggestions for sites I could try etc?
Thanks in advance.
Regards
p.s DVD playback to my monitor is okay.
AMD Duron 750Mhz
256Mb PC 100
LG DVD ROM DRD8120B
Win 98
Thanks in advance.
Regards
