Help! Newbie trying to build a computer for home!
So I'm trying to build a computer for the home that both my mom and I could use. Now, I want to keep my budget under $300, but I'm not sure this combination works nor if it is as optimized as I can get for my money. Please evaluate on the fitment and the quality of the parts involved. Help would be greatly appreciated.
Rosewill RANGER-M Dual Fans MicroATX Mini Tower Computer Case
Item #: N82E16811147122
Seagate Barracuda Green ST1000DL002 1TB 5900 RPM SATA 3.0Gb/s 3.5" Internal Bare Drive -Bare Drive
Item #: N82E16822148764
Foxconn M61PMP-K AM3 NVIDIA MCP61P Micro ATX AMD Motherboard
Item #: N82E16813186189
LOGISYS Computer PS550E12 550W ATX12V Power Supply
Item #: N82E16817170019
G.SKILL Value 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9S-4GBNT
Item #: N82E16820231423
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
Item #: N82E16819103727
Grand Total: $296.74
13 answers Last reply
More about help newbie build computer home
  1. The thing which sticks out, as just plain wrong, is the power supply. I'm not even sure it would fit in that case, but it doesn't really matter, as 550W is way too much for that build. Without a graphics card you don't need much more than 200W. Even if you were to add a graphics card, you wouldn't use a powerful one, in that build, and somewhere around 350W, 400W max, would be fine.
    I'm loathe to suggest one, as they are often rubbish cases, with even worse power supplies, but, given your budget constraints, it may be worth looking at a mini case with built-in power supply. Avoid the really cheap and nasty ones.
    There's nothing wrong with the rest of it, given your budget. Whilst I wouldn't claim they were exceptional, or anything, it might be worth considering an AMD Llano processor, which have half way decent graphics, built in, for a bit of light gaming, if you want that (they require a different motherboard).
  2. what is your
    budget
    location
    parts not required
    ill build something from that info
  3. The build you suggested simply won't work.
    The good news is i made you a much better one that will work for about the same price.
    CPU: AMD A6-3650 2.6GHz Quad-Core Processor ($76.49 @ Amazon)
    Motherboard: MSI A55M-P33 Micro ATX FM1 Motherboard ($44.99 @ Newegg)
    Memory: G.Skill 4GB (2 x 2GB) DDR3-1600 Memory ($24.99 @ Newegg)
    Storage: Seagate Barracuda 1.5TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Newegg)
    Case: Xigmatek ASGARD PRO (Black) ATX Mid Tower Case ($39.99 @ Newegg)
    Power Supply: Antec 400W 80 PLUS Certified ATX12V / EPS12V Power Supply ($29.70 @ Newegg)
    Optical Drive: Lite-On iHAS224-06 DVD/CD Writer ($18.99 @ SuperBiiz)
    Total: $305.14
    (Prices include shipping and discounts when available.)
    (Generated by PCPartPicker 2012-09-08 09:15 EDT-0400)
  4. I do not need an optical drive, like a CD/DVD player. My location is Michigan, United States. I want to get a build for around 300 or less if possible.
  5. If you've got a compatable opt drive, just swap it out, but for what they cost, it just doesn't make sense not having one at all. That's a nice build, for your budget, that Kamen_bg's put together. There really is no way to reduce it, and keep some sort of performance, other than go for a combined case/PSU, and I'm afraid you get what you pay for; a cheap one is almost guaranteed to be rubbish.
  6. kamen bigs build will do but i would change the case to a fractal core 3000 as it is higher quality overall
  7. Ok, how would you guys compare the processor Kamen_big put together versus this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727. Should I try to build around the Phenom II? Also, thank you Kamen and everyone else for just warm support. First time building a computer here. :)
  8. you showed a whole list of chips.
    the a6 is about as good as the athlon II x4s. no where close to a phenom but you cant really fit it into your budget
  9. I meant to show this: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727 AMD Phenom II X4 965 Black Edition Deneb 3.4GHz. Any way to build around this for around the same price?
  10. not really since the phenom ii needs a graphics card which means you will have to spend more money
  11. What would you and your mom like to do with this computer? Do you have a linux distro
    ready to go on a usb flash/thumb drive? Does it have to be this processor, or can it
    be a intel dual core? If we knew your country, state/province and municipality we could
    suggest the best combo of parts for you from the sites and/or stores that will save you
    the most money based on that(currency and exchange rates may factor in too).
  12. We would not be gaming with this. It would be just for casual use, downloading movies, music, watching videos, browsing the web. Would the quad-core be beneficial for me in this case over a duo? The lower the cost, the better it would be. I am located in Rochester Hills, Michigan, United States. Also, does increasing RAM to 8GB over 4GB make a noticeable difference in performance?
  13. oops. I didn't see a few posts back you are in Michigan. That could change prices 4 u.
    A dual core would work very well for what you want to do. You would see little to no
    difference between a dual and a quad. The reason I asked about Linux and a flash drive
    was because you said no optical drive and didn't say anything about windows . Generally
    an oem copy cannot be transferred to another mobo and most people don't buy a retail
    copy. If you already had a Linx distribution that you liked ready to go on a cheap flash
    drive you could just set the bios to boot from it and/or install it on the hard drive. There
    are many different flavors of linux but there are tools online to help you pick. You can
    even download a whole cd or dvd worth of potential linux OSes, copy them to a usb drive
    and try them out. Larger distributions may include multiple office suites, media players,
    browsers, and more. Smaller ones will have like one or two of each of those. You can look
    to see if the desktop and user interface would be something you both could easily use.
    Oh yeah. here is a very lean build on pcpartpicker.com : http://pcpartpicker.com/p/gUzE
    The mobo will output video from the processor's integrated graphics through the vga
    port or the dvi port. If you need hdmi out, you can buy a dvi to hdmi adapter cheap.
    4GB of ram will be plenty for your needs. There is a microcenter computer store near you.
    32800 Concord Drive
    Madison Heights, MI 48071
Build Computer Systems Product
