PC turns on from PSU switch (not power), only stays on for 2 seconds
Last response: in Systems
Hello, I hope someone here can help me with this.
I recently just got parts for my girlfriend's mom's computer. Ive built plenty of high end machines but this one she only had a budget of $400 so I put together the following build:
MB ASROCK|H61M-DGS HD61 LGA1155 R
CASE COMPUCASE|6K28BB8F RT
VGA MSI|R4350-MD1GD3H/LP HD4350 1G
PSU ROSEWILL|RV350 350W RTL
CPU INTEL|CORE I3 2120 3.3G 3M R
MEM 4G|CORSAIR CMX4GX3M1A1600C9 R
HD 500G|WD SATAIII WD5000AAKX %
DVD BRN ASUS | DRW-24B1ST/BLK/B/AS%
I've double checked that everything was plugged in. After that I turned on the PSU switch in the back to initiate the power, but when I did that, the power of the computer went on, for about 2 seconds, then turned off. Any time I tried to press the power button in the front of the PC, nothing happened. I tried changing the position of the power button cable to all the different slots on the mobo just to ensure that mine was on the right two pins. But, no avail. The only time the computer starts now is when I shut the PSU switch off for a few moments, and return it back on, but it only runs for 2 seconds and automatically shuts off!
I've never experienced anything like this. My only guess is maybe that the power button on the case is shorted? but if that's the issue how could I figure it out? Its not like I have another spare case sitting around.
Please help, the last thing I want is my girlfriend's mom on my case :pt1cable:
Related ressources
xwgpx55 said:
Does anyone not see the weirdness of the PC only turning on when I flick the PSU switch? why the hell would it be turning on from a PSU switch?
the weirdness is that the mainboard is probably failing a self check, which usually goes through the process of can i initialise
CPU, RAM, GRAPHIC. If yes, then start bios and go through post check. If no, then perform diagnostic outcome. This used to be a series of beeps on the PC speaker, but nowadays it may be a light or other - check the motherboard manual.
or could be a faulty PSU or too much drain on the PSU.
edit: could be a short aswell, and the PSU is shutting down for safety.
Ask the community
