Hello,
Hi, so ive just put together my first pc, specs include.
-ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
-Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor
-SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
- EVGA 01G-P3-1556-KR GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit GDDR5
-OCZ ModXStream Pro 600W Modular High Performance Power Supply
- Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED
-G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800).
Now, I believe i have installed all of the hardware and wiring correctly, but when I turn on the pc, the mobo displays an error code "64", which according to the manual means CPU DXE initializing. Ive attempted turning the thing on without anything but the bare minimum connected (ram, cpu, psu) but nothng seems to be working.
Not sure if this will help, but the cpu fan is a stock, and it only twitches once when I turn it on.
