I've had my PC about 6 months. I have a:
-cooler master HAFX V2 case
-700w PSU
-4x4GB RAM
-AMD FX 8150 CPU
-NVIDIA GeForce GTX 570
I have 3x200mm fans in the case, and 1x230mm fan. The front/side are ins, the top 2 are outs.
Recently, whilst playing Saints Row III on ultraspec (normally fine), during big explosive sequences I've noticed my CPU hitting 65-66 celsius, even though I was told by the PC guys that built my rig that the H60 corsair water cooler would work fine. Is there anything that may be screwed up in the cooling unit's installation etc, or is the CPU running at 65 degrees okay? Just that my PC comes up with a warning message every time it hits that temp, and I read elsewhere that 61 degrees is the max safe temp for the FX 8150.
Don't wanna fry my beast!!!
-700w PSU
-4x4GB RAM
-AMD FX 8150 CPU
