Closed
Help with DP motherboard power supply
Last response: in Components
Hello, I have just purchased a supermicro X8DT6-F http://www.supermicro.com/products/motherboard/QPI/5500...
I have the procs coming and memory as well but I was showing the photo of the board to my wife when I noticed it has *TWO* EPS12V power sockets (which honestly makes sense with it having two procs). Problem is, my 650w PS only has *one* of those plugs. That PS should be *more* then enough considering what it will be used for but I need to know if I can buy some sort of splitter and split the EPS12V cable or some form of adapter and pull power off some 4pin molex connectors.
Thanks for your help!!
