PSU with no 6-pin PCI-E to power 2x6-pin GPU
Last response: in Components
- Can I use a 2x6-pin PCIe GPU with a 1x6-pin PCIe connector PSU - Forum
- Upgraded GPU that Needs 2x6-pin PCI E But Only Have 1 6-Pin! What should I do?! - Forum
- can i turn a sata 2 cable into a pcie 6pin power cable for a gpu? - Forum
- Faulty PCi-e 6pin power? Same problem as Zombiemodd, except new and better PSU - Forum
- 1x6 Pin PSU with a 2x6pin GPU - Forum
- What is a 2x6pin pcie power slot? Forum
- I just bought a 7870 for my rig, my psu has 1x6 pin power for the gpu, but i need another 6 pin. It came with a 6pin to molex Forum
- Solved6pin AUX to 6pin PCI-E connector possible for modular PSU? Forum
- SolvedI want to buy a Sapphire R9 270X Vapor-X 2GB GDDR5 but my PSU has only one 6pin PCIe Forum
- SolvedHow do i connect my 8pin gpu to my 6pin psu? Forum
- SolvedCan I Convert Two 4pin Molex Connectors to 6pin PCIe to power AMD HD7870 Forum
- PSU with one 6-pin PCI-E to two 6-pin Forum
- SolvedPowering my R9 270X with one PCIE 6-pin and a dual molex to PCIE 6-pin? Forum
- SolvedDo I hook up 2 PCIE 6-pin connectors to gpu? Forum
- SolvedPsu advice needed - 6pin power draw check Forum
- SolvedWhere to find PCI-e 6-pin connector TO power supply? Forum
- SolvedPossible to connect GPU 6-pin to PSU 8-pin header? Forum
- Using two seperate PCI-E on my 280x's. One with 8pin and the second with 6pin per gu (2x PCI-E per GPU) Forum
- SolvedIntel DG41RQ has 6-pin PCIE power connector ?? Forum
- SolvedWhat is the best way to plug an 8-pin GPU into a 6-pin PSU? Forum
- More resources
Read discussions in other Components categories
I still have unused 2x4-pin molex from 2 different 12v rail that was hooked up on my current GPU and planning to add another 2x6 molex to 6-pin, so that makes (2) 6-pin PCI-E's.
I ran it with FurMark and MSI Kombustor burn in test with no errors or problems. Also, i've noticed on the label on my PSU, it stated that the combined 12v1 and 12v2 = 38A. So, i think my PSU can really handle it! Been using it for almost a week now and my only problem is the heat that the new card is producing
