Tom's Hardware > Forum > CPU & Components > Sound Cards > SB Audigy & VIA Chipsets - What's the Problem?
Forum CPU & Components : Sound Cards - SB Audigy & VIA Chipsets - What's the Problem?
Hey all! I'm wondering about this supposed incompatibility of the Sound Blaster Audigy and VIA chipsets. I have a VIA KX133 mainboard and ordered a Sound Blaster Audigy Platinum earlier this week. About 15 minutes after I placed the order, I heard of this compatibility problem. However, no one has mentioned if it happens all the time, if it can be worked around and how severe the symptoms are. I have a Sound Blaster Live! which is supposed to have problems too though I have never experienced any.
Basically what I hope you guys can tell me is, does this problem happen all the time (i.e. is it guaranteed to happen to me) and if so, is there a workaround for it or is it a driver issue? My supplier will refund my purchase of the Audigy bu tonly if I don't open it first. So I want to know whether or not I should try to install it or just send it back right away because there's no point in trying. Can anyone help me out? Thanks everyone!
Parallax Abstraction,
Senior Rogers @Home Computer Technician
Ottawa, Ontario, Canada
Sponsored Links
No, I don't think you will be affected like other people. The problem became serious after the release of the 686b southbridge which is not included with the KX133, I believe.
AMD technology + Intel technology = Intel/AMD Pentathlon IV; the <b>ULTIMATE</b> PC processor
Reply to AMD_Man
No, the 686B came out quite some time after the KX133. Here's a question though: I plan to buy a KT266A (note the A) mainboard when they come out in a month or so so that I can upgrade this bucket back to hotrod status. :) Those boards don't employ the 686B do they? I don't believe they do (I think the KT266A has a different southbridge), but does anyone know? If the KX133 isn't affected, I'll definitely throw the Audigy in here and see what happens.
Reply to PXAbstraction
KX266A will not use the 686B. Via state that the chipset will not have problem with Creative sound card.
Reply to upec
Lovely! Thanks for the help all!
The KT266a uses the 686c Southbridge.
I haven't heard of any problems with the Audigy. Got any links?
<font color=green>In memory of all the Americans that died 9/11/01
Rest in peace</font color=green>
Reply to FatBurger
NO, KT266 uses VT8233 southbridge which support the V-Link Hub Architecture.
Reply to upec
There are 1251 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
