Sign-in / Sign-up
Solved
Can I run a GeForce 9800 GTX+ on a Gamer Power 562D3 desktop with a 585 watt pow
  • Graphics Cards
  • Desktops
  • Power
  • Geforce
  • Graphics
  • Product
Last response: in Graphics Cards
July 23, 2012 7:21:45 AM
Just one simple question here.
I just bought a Gamer Power 562D3 gaming desktop from Newegg.com and I was just wondering if it would run an Nvidia GeForce 9800 GTX+ if I upgraded the power supply to 585 WATTS. I have both the GTX+ and the power supply (which is an Orion brand) just waiting in my closet to be used.
LINK TO THE SPECS OF MY NEW DESKTOP:
LINK TO SPECS OF MY 9800 GTX+ VS THE AMD RADEON 6670 THAT COMES WITH IT:
http://www.hwcompare.com/10929/geforce-9800-gtx-vs-rade...
If the Gamer Power 562D3 computer cannot not be upgraded like this, please explain.
More about : run geforce 9800 gtx gamer power 562d3 desktop 585 watt pow
a b U Graphics card
July 23, 2012 7:27:43 AM
Yes you can, since you have both, then go for it. You should be able to replace the PSU in your computer. Just make sure your PSU has the amps to push the 9800 GTX+
m
l
a c 198 U Graphics card
July 23, 2012 7:31:51 AM
What are the amps on the 12V rail for that PSU?
The 9800GTX should be much better than the 6670.
m
l
a b U Graphics card
July 23, 2012 9:25:05 AM
i think the 480w psu will support your gtx+ just fine
m
l
Best solution
a b U Graphics card
July 23, 2012 10:00:24 AM
Thats not how it works;
Please google your PSU model number/brand and paste the specs here:
#1 How many rails?
For your card id recommend around 32 amps minimum. If you have a SINGLE 12v rail, simply divide 585watts by 12v = 48 amps. Should be sufficient, thought that card draws considerate power.
However many cheap brand PSU's dotn come with a single rail and thats where the catch is, you will end up having ~24 amps which will bottleneck your card.
Watts themselves are irrelevant as I could have a 850watt PSU that performs much much worse than a 650watt PSU.
July 24, 2012 5:18:04 PM
My PSU:
Model
Brand
hec
Model
HP585D RETAIL
Spec
Type
ATX12V
Maximum Power
585W
Fans
2 x 8 cm DC Fan
Main Connector
20+4Pin
+12V Rails
PCI-Express Connector
1 x 6-Pin
SATA Power Connector
SLI
No
CrossFire
No
Modular
No
Power Good Signal
100-500ms
Hold-up Time
16.6ms min.
Efficiency
> 75%
Over Voltage Protection
Yes
Overload Protection
Yes
Input Voltage
90-130V or 180-264V
Input Frequency Range
47 - 63 Hz
Output
+3.3V@36A, +5V@36A, +12V1@19A, +12V2@20A, -12V@1A, +5VSB@2.0A
Dimensions
6.5" x 5.9" x 3.4"
Features
Connectors
20+4 Main Power Connector Supports Latest "Desktop Motherboards"
1x 6 pin connector for PCI Express Cards
4x Molex Connectors
1x Floppy Drive Connector
3x SATA Connector
Features
Compatible with Intel Pentium 4 and AMD
Dual 8 cm fans for better heat dissipation
Super Quiet Technology: Smart Fan Control Function Keeps Noise Level Under 22dBA
Excellent Protection Functions Provide Maximum Reliability: OVP (Over-Voltage Protection), UVP (Under-Voltage Protection), OPP (Over-Power Protection), SCP (Short-Circuit Protection)
High Energy Power With Low Ripple Noise
100% Hi-Pot, Chroma & Burn-in Function Tested
Dimensions & Weight
Dimensions
5.9" x 6.3" x 3.3"
Manufacturer Warranty
Parts
1 year limited
Labor
1 year limited
m
l
July 24, 2012 5:19:49 PM
#1 How many rails?
it says that my Orion HP 585D power supply has TWO 12v rails. so 585 watts divided by 6? is that right and is this PSU good or bad?
m
l
July 24, 2012 5:33:52 PM
get the 6670, it's a lot better than a 9800 gtx. Btw, stop using that site to compare hardware, it's so terrible and doesn't represent that actual performance in games.
m
l
July 24, 2012 8:49:42 PM
stop writing bullshit comments to waste my time. the computer i just bought already comes with the 6670, and no, it is definitely not better than the 9800
m
l
July 24, 2012 10:48:31 PM
Best answer selected by mrblankslate.
m
l
