Hi
My system runs with MSI GeForce GTX 560 Ti SLI and i seemed to have some heat problems on GPU 1. So i tracked my GPU's over a shorter period and found that my GPU 1 goes to a minimum of 70 degrees while running fx. Battlefield 3, and that got me worried.
I then noticed that GPU 1 used ~ 90-100% and GPU 2 0% and got me thinking that since that i build this system i actually havent ever seen my GPU 2 Usage go up. Should i run like that? I always imagined sli to share the usage between the 2 cards?
As i'm not long time experienced with SLI i would very much apreciate some feedback on this?
System:
ASUS P8Z68-V PRO/GEN3, Socket-1155
Intel Core i7-2700K Processor
Corsair Vengeance DDR3 1600MHz 16GB CL9
Regards
Danny Christiansen [Denmark]
System:
Regards
