I'm building a new Computer (i need help!)
Components :
Motherboard - Gigabyte SKT-AM3+ 990FXA-UD7 Motherboard (Rev 1.0)
CPU - AMD FX-8150 Eight Core Processor - 3.60GHz, 16MB, L3 Cache, Socket AM3+ ( Box Contains - 1 x Seagate Barracuda 2TB Sata Int )
CPU Fan - Arctic Cooling Freezer 7 Pro Rev.2 CPU Cooler
RAM - Corsair CMZ8GX3M2A1600C9 8GB 1600MHz CL9 DDR3 Vengeance Memory Two Module Kit
Graphics Card - Sapphire 11191-02-20G HD 6570 2GB DDR3 Graphics Card
Hard Drive - Seagate Barracuda 3.5 inch 500GB 7200 RPM 16MB 6GB/S Internal SATA Drive
DVD drive - Sony AD-7280S-0B 24x Internal SATA DVD Multi Writer Black Bare
Power Supply - CiT 750W Power Supply Unit with PSU and Dual 12V Rails - Black Edition
Computer Case - Sharkoon T9 ATX Midi Tower Case – Green
Operating System - Microsoft Windows 7 Home Premium with Service Pack 1, 64-bit, English, 1 Pack, DSP OEI (PC) (This OEM software is intended for system builders only)
Total Approximately - £652.10
( There the component's i would like, i have a budget of £700 and i have keep within it i need to find out weather this is all compatible with one another and if the psu is big enough and stuff like that, would appeicate the help very much Thanks :) )
4 answers Last reply
More about building computer help
  1. TSmithy95 said:
    Components :
    it should, the only thing that i see is that you might want a different case because that one might give you size constraints and bad airflow
  2. What case would you recommend ?
    i loike the HAF 912 or the Storm enforcer from cooler master, and a 300r from corsair but i think that is a little expensive for this build
New Build Systems
