What is a good temp/fan speed ratio for a GTX 680?
I noticed my GTX 680 was going over 75 degrees but only had a fan speed of around 55%.
So I adjusted it so that the temp is around 63-64 degrees and the fan speed is around 70%
I just don't want my fan to break nor my card to overheat.
Trying to make the life of my card longer.....if thats possible.
1 answer Last reply
More about what good temp speed ratio
  1. 75 degrees isn't that hot, but if it goes above 85-90, you should start worrying.
    Putting the fan speed to about 70% won't break it or anything. Does the noise increase fairly too much such that it's a little discomforting. As far as I can see, increasing the fan speed won't disturb your GPU.
Graphics Cards Gtx Fan Speed Graphics
