Solved
Low Speed CPU Fan
Hello, I've been looking for a low speed cpu fan (1000 rpm or slower) that I can connect to a regular 12V battery. It seems like most I've seen have pin connectors and that would probably not work. Thanks!
2 answers Last reply Best Answer
More about speed
  1. Best answer
    If you find the speed fan you desire, simply cut the connector off and use the 1st 2 wires. They will be +12V and ground... + and -
    http://www.allpinouts.org/index.php/Motherboard_%28CPU%29_4_Pin_Fan
  2. Best answer selected by bluejay12.
Cooler Master Battery Connection CPUs Components
