Solved
GTX 550 ti frame rate issues
I currently have a GTX 550 ti 1 GB but i've been getting low frame rates in games like BF3 where ive been getting somewhere between the 20's and low 30's on medium. When i checked online i see people with similar specs as me getting way higher and easily running it on high. Could this be because of my old AM2+ mobo and DDR2 ram? would upgrading to a AM3+ motherboard with DDR3 1600 help with performance. I dont think its my CPU as its an Athlon ii X4 620. My temps for the 550 ti are around 55C and about 33C for my cpu while playing BF3.
6 answers Last reply Best Answer
More about frame rate issues
  1. i have the gtx 550ti i would upgrade to a amd phemon x4 am3 cpu like the amd phemon x4 840 thts what i have and ddr3 ram its wroth it
  2. what if i upgrade just the motherboard to a AM3+ and DDR3 1600 ram, would there be a noticeable performance increase?
  3. Best answer
    that would help and getting a phenomIIx4 is also a great help. sorry that athlon is not all that great . .
    but get the mobo and ram first. see what happens and maybe by that time piledriver will be close to getting released and see if the PII or PD would be a better upgrade.
    Thats exactly what i was thinking. Desent make sense to me to upgrade to a phenom right now or even a bulldozer.
  5. ^+1
    Yes do the upgrade on the MOBO and RAM first because you need to help the 550 anyway you can. Even though they are kinda at the bottom of the barrel but they do ok for that.
    I am not a big fan even though I own two of them and seeing what fps you are getting in BF3 at med settings. You did better than my two cards when my son tried to play and he was on low settings. Don't figure good luck to you.
  6. Best answer selected by sags95.
Graphics Cards Gtx Battlefield Graphics
