Hello
My previous thread:
http://www.tomshardware.com/forum/361310-31-serious-issue-cooling
This thread was about the issues I am having with cooling. My 3770k is getting up to 70-80 from intense use. Which shouldn't get that hot stock with an H80 liquid cooler.
I need a case that can fit my motherboard and H80. My current case just doesn't fit because the motherboards thermal and pump thing are blocking at the top of my case for usage there. And there's only enough room for the radiator and 1 fan for the top left corner.
Motherboard: ASUS Maximus V FORMULA LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131854
Liquid CPU Cooler: CORSAIR H80 (CWCH80) High Performance Liquid CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181016
Case: NZXT Phantom 410 CA-PH410-B1 White Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146087
I think I need to return the case and get one that can fit properly.
My previous thread:
