Metro 2033 resolution problem
I have a problem with my metro 2033
I cannot play this game because when i run it i receive a message from monitor which says "Cannot display this resolution,,,,Optimal resolution 1280x1024x60Hz
THen i must reboot computer in safe mode and logging with low resolution because when i reboot in normal mode it still keep saying the message
i just made some modifications on the user.cfg file and opened the game in windowed mode
but when i play this game in windowed mode i receive 100% gpu load even in minimum settings
NOTE: GPU load is 60-70% when in fullscreen but with the same framerate with 100% gpu load in windowed mode (i tested this with a lot of games NFS the run etc)
SO i love my pc and i dont wonna broke it
Pc specs 8 gig ram core
i7 2600k 3.4GHz
ASUS GTX 680 2gig
9 answers Last reply
More about metro 2033 resolution problem
  1. what res is the native for your monitor?
    You can never exceed this, if you try to in windowed mode the GPU will scale the image, which increases load while doing nothing to improve what you see.
  2. Is 1280x1024 60Hz My desktop is on the same resolution
  3. your monitor probably doesnt work with 16:10 ration resolutions try another 16:10 ratio
    resolution i.e. 1440*900 and tell us
    No if there is one pixel more than 1280 or 1024 this message is displayed
  5. ok then why dont you try forcing the resolution through nvidia control panel?
  6. Basically your monitor is garbage, you are saying the maximumm res your monitor can support is 1280x1024? You need an urgent replacement loool.
    I dont know if metro can run at that res, but all you have to do is go into the game/profile config file and change it to that res.
    I've changed that ,,i've changed and refresh rate 60Hz but still the same problem
  8. maybe read this and try some of the suggestions there:
    http://forums.steampowered.com/forums/showthread.php?t=1442765
  9. Your optimal resolution is 1280X1024? That's too low, and it will result in a bottleneck for your GTX680..meaning your GPU won't be working at it's full potential.
    Upgrade to a 1080p monitor.
Graphics Cards Games Resolution Graphics
