Hi,
I currently have a Dell PC that I have made various upgrades to (CPU, GPU, USB 3.0)
Recently I turned the PC off using the power button on the case (from the boot-selection menu) and when I came to turn it on again, nothing, not even a flicker of power. It was as if it was unplugged. Switching it off at the plug and waiting for all power to leave the PC (about 15 seconds) fixed the issue and it worked fine. Now, this is not a new issue, but recently it is happening more often. At first I thought it was just a random error or something, and thought nothing of it, but it happens more and more now and I am wondering what causes it.
Stuff you should know:
It happens every time I power off using the button on the case, when I have no other option (pre-boot)
It rarely happens when I power off from the OS (Win 7) but does occasionally
The problem surfaced around the time I upgraded the CPU, but no other problems have arisen from it
All I can think of is that it may be some problem from the PSU as it may not be coping with the higher demand from the upgrades (as it is a Dell PC)
Hope you can help
Hope you can help
