Closed
Is this power supply enough for this gaming build
Last response: in Components
Best solution
Power supply Master
Gaming Expert
Topower is not a tier one brand; don't go by the wattage alone. Here's two better brands: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
http://www.newegg.com/Product/Product.aspx?Item=N82E168... (no power cord included). I highly recommend you buy everything at once so you can test them all together, since most items have a 30 day return policy. Save your money and be patient. It will pay off in the long run.
Related ressources
First of all Don't get the 965, it will bottlneck your GPUs big time. FX 8350 or I5-3570k would be your best choice.
Get a bigger harddrive, that is suicide, building a great gaming rig with no space for all the games? Just no.
http://pcpartpicker.com/part/xfx-power-supply-p11050bef... This PSU should do fine for your needs.
If I were to give you any advice then I would cut one of the GPUs and have more money for better harddrive, CPU, case, MOBO and RAM. That gaming rig is way too unbalanced. By doing that you would also save some money on the PSU.
yea i was thinking about not getting 2 cards and already took out one. and that waasnt an exact rig i just did it for power consumption figure really quick. i gunna get a 1TB for games and a 32gb ssd for windows
