$1500 Budget.
Are all the components of this build compatible ? And what kind of performance should i expect?
CPU: Intel Core i5-3570K Processor http://www.amazon.com/dp/B0087EVHTE/ref=asc_df_B0087EVHTE2179814?smid=ATVPDKIKX0DER&tag=hyprod-20&linkCode=asn&creative=395093&creativeASIN=B0087EVHTE&hvpos=1o3&hvexid=&hvnetw=g&hvrand=14491937851421690501&hvpone=&hvptwo=&hvqmt=
MOBO: ASRock Z77 Extreme4 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
CPU Cooler: COOLER MASTER Hyper 212 EVO Sleeve CPU Cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Memory: G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) http://www.newegg.com/Product/Product.aspx?Item=N82E16820231550
Storage: Western Digital 500 GB WD Black SATA III 7200 RPM 64 MB Cache Bulk/OEM Desktop Hard Drive http://www.amazon.com/Western-Digital-WD5003AZEX-Frustration-Free-Packaging/dp/B008968L6M/ref=dp_ob_title_ce
SSD: OCZ Vertex 4 64GB http://www.amazon.com/dp/B0081O7K0K/ref=asc_df_B0081O7K0K2179814?smid=ATVPDKIKX0DER&tag=hyprod-20&linkCode=asn&creative=395093&creativeASIN=B0081O7K0K&hvpos=1o1&hvexid=&hvnetw=g&hvrand=18974009341099984330&hvpone=&hvptwo=&hvqmt=
Video Card: EVGA GeForce GTX 670 2GB Video Card http://www.amazon.com/EVGA-Dual-Link-DisplayPort-Graphics-02G-P4-2678-KR/dp/B0083Y6MV6/ref=br_lf_m_1000825151_1_1_ttl?ie=UTF8&m=ATVPDKIKX0DER&s=electronics&pf_rd_p=1394592842&pf_rd_s=center-3&pf_rd_t=1401&pf_rd_i=1000825151&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0988NEKJRAG4M5PB5FJE
Case: Corsair 650D ATX Mid Tower Case http://www.amazon.com/Corsair-Obsidian-Aluminum-Enthusiast-Computer/dp/B004UE1W9K
Power Supply: CORSAIR Professional Series HX650 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Microsoft Windows 7 Home Premium SP1 64-bit
Thanks!!!
Thanks!!!
