Replacement case for HP DC5700s small form factor pc
September 13, 2012 4:43:20 AM
Hello, I have an HPDC5700 s small form factor pc. I wish to upgrade the power supply, but it seems that a standard square atx power supply wont fit. So I am looking to see if I can remove this mobo and put it into another case..that has a standard size atx power supply. I am having a hard time finding solid results. Could I use a standard atx case for this mobo, or do I need to go with a micro atx case? The more room the better;) Thanks
