Well, well, well... this has been challenging. But i seemed to have made a progress, check it out:
Quote:
What CPU fan are you using and what happens to the fan RPM under load (IE @ what temp does it max out)?
Well, i can't seem to find out what CPU fan i'm using, since it doesn't appear on SpeedFan (as it should). I also checked the speeds and the result is simple: the hotter, the faster. When my CPU is idle, my fan is slow, and when it is under load, then it is at its full speed. SpeedFan doesn't seem to help me more as it doesn't tell my fan model neither the RPM. But it all seems to be alright.
___
Quote:
So....please don't take this the wrong way, but If there is a smoker in the house, you may need to take your notebook in to have it cleaned. Nicotine oils build up on the inside of you PC and prevent it from cooling efficiently. The only way to fix this is to disassemble the cooling system and clean it. I fix about 6 laptops a month from this issue.
Actually, i don't believe that my computer has ever been in contact to any kind of smoke, gases, or nuclear weapons. So, there is actually no problem on this side.
___
Quote:
It also sounds like you may have put too little of the thermal paste on. You certainly should not have seen higher temps at least not by more than 2-3 degrees.
I changed the thermal paste twice, so i'm pretty sure i did it right. No problem here neither.
___
But it was this one that caught my attention:
Quote:
Check all your BIOS settings to see if they are correct for your CPU, you may have accidentally overclocked it. Allso check the BIOS for correct cpu fan operation.
Well, you see, after i read that i turned the computer off and checked my BIOS settings. I happens that i couldn't find anything about my fan on the BIOS. But, when i came to see my CPU settings i saw that the frequency limit for my processor was at 2.00 GHz. I looked out my model on the internet and found out that is limit is in fact 2.00GHz. So there is no overclocking, right?
WRONG
I installed CPUID CPU-Z just to be sure of what i found out. I saw that my cores are not running at 2.00Ghz but it was nearly 2.9GHz! And i was all like: "Who the hell told you to overclock!? Get back to normal right now!". Well, i screamed with my computer to no avail, as my BIOS doesn't show any overclock settings and there is no "booster" program installed to do so. Also, there are no viruses on my computer since i formatted it (and before formatting i checked with Avast!).
So the real problem here as a involuntary overclocking.
Any of you guys know how to solve this? I mean, i've been monitoring my temperatures for over a week now. Every second. Now i'm also going to monitor my CPU settings with CPU-Z.
Does anybody have a clue?
