TheBigTroll :
a UPS is a battery backup and a surge protector in one. just that one is smaller and one is bigger.
if there is a surge, the UPS will just eat it up and will protect the pc
Kursun :
Yep, all good UPS are also good surge protectors.
On the downside UPS consume electricity on their own even when they are sitting idle. (about 15W)
TheBigTroll :
but you do get more protection (quite a bit more)
oh, i see. sounds like a sweet deal. im not worried about the extra 15W and i would get more protection. i think i'll just get a UPS then. thanks guys.
can either of you recommend a high quality one that has a high enough watt, voltage, and amp output to power the PSU i described, 3 of these monitors --> ASUS VE247H Black 23.6" 2ms Full HD HDMI LED BackLight LCD Monitor w/Speakers 300 cd/m2 10,000,000:1 (ASCR), and then have some power left in case i ever hook anything else up to it.
will i need anything to hook the UPS up or not?
edit: i would rather not pay out 600 bucks to get a 1650 watt UPS. if there aren't any 1600 watt or higher UPS's for less than 150 bucks, then can you recommend a good surge suppressor (less than 150 bucks) that has a watt output capacity of at least 1600 watts.
