Solved
Should I get a bigger power supply?
  • Power Supplies
  • Build
  • Components
Last response: in Components
January 27, 2013 7:35:22 PM
So I was looking over pc parts that I'm going to get and I was wondering if I should get a bigger power supply (I'm not that great with all this pc mumbo jumbo so I have no idea)
The build is here
http://pcpartpicker.com/p/zwtD
Should I get a 750w psu or should I be good with the 550?
Thanks :bounce:
More about : bigger power supply
January 27, 2013 7:56:32 PM
Compromise; 650W
m
l
January 27, 2013 8:14:18 PM
Are you looking overclock any hardware in the future?
m
l
Best solution
a c 311 ) Power supply
January 27, 2013 8:18:53 PM
The build is here
Thanks :bounce:
Hi - realhardtech suggests a 550w unit for a system with
a gtx680, and there's headroom built into that.
So, you are good to go the the XFX550. You only
need more if you plan on SLI in the future.
There's no harm to your computer in getting more PSU
power than you need, but it's a higher (unnecessary)
up front cost. I chose that route myself, needed 450
got 650.
Tom
a b ) Power supply
January 27, 2013 9:28:14 PM
The most important point in buying a psu is quality. Go with a good brand that stands behind their product and honors their warranty. Check reviews using RealHardTechx.com's review database. Stated wattage means nothing there is no standard using to measure output. You only have the reputation of the brand.
m
l
January 27, 2013 9:58:04 PM
The build is here
Thanks :bounce:
BTW - The XFX(Seasonic built) you selected is a quality unit:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
Tom
m
l
a b ) Power supply
January 27, 2013 10:07:08 PM
I looked at you build and I would spend a little more money on the mobo. Look at Z77 mobo and higher end brands like Asus. The 680 deserves it.
m
l
January 28, 2013 3:17:03 PM
got 650.
Tom
Alright thanks for the help. I'll probably get a 750 just for the extra power in case I do SLI in the future. (It makes it run better correct?) It's not much more expensive so it's better to probably get that :p
Edit: New PSU: Antec HCG-750
the build with it: http://pcpartpicker.com/p/A5Nt
m
l
January 28, 2013 6:23:42 PM
Good choice - I did something similar needed 450-500w
and got a 650.
Tom
m
l
January 28, 2013 6:27:47 PM
Best answer selected by kekoslayer29.
m
l
