Help with 560 TI/Power Supply
July 26, 2012 12:28:13 AM
I have a Raidmax 850SS and the computer will not power on at all when I have my 560 hooked up.But when I plug in my GTS 250 it works like a charm.I thought if a power Supply went out...it went out?
More about : 560 power supply
a c 1411 U Graphics card
a c 716 ) Power supply
July 26, 2012 12:51:56 AM
Raidmax is notorious for not delivering what it promises. Looks to be the case here unless you have a card that has a short on it.
Reading the sticker on the rx850ss on newegg it states max combined current for +12 volts is 50amps x 12volts = 600watts, yet above it it says 696watts. Simply does not compute!
m
l
July 26, 2012 12:55:14 AM
thanks for the info
m
l
a c 198 U Graphics card
a b ) Power supply
July 26, 2012 7:57:03 AM
I dont like Raidmax, but it should be able to power something like that honestly. It might be the problem.
Try the card in a friend's computer.
m
l
